src1425
A slightly different take on an earlier question, regarding optimal cooling for the CM 690 II Advanced. As you can see, it has numerous fan options, and since I'm going to replace my cooler, I may as well add a fan or two while I'm at it.
Stock fans are 140mm intake in the front, a 140mm exhaust at the top, and a 120mm exhaust at the rear.
Option 1: add another 140mm exhaust fan on the top and a 120mm intake fan on the bottom
Option 2: remove the front 140mm fan, add another 140mm exhaust fan on the top and two 120mm intake fans on the bottom (the bottom half of the HDD cage can be removed).
Option 3: add another 140mm exhaust fan at the top and a 120mm intake fan on the top HDD cage
Or, Option 4, something else?
Thanks in advance for any suggestions!
