- Mar 31, 2003
- 11,679
- 0
- 81
So in an earlier thread, I posted that I was flushing the clutch fluid in my car. I think the problem is bigger than that.
When I am starting from a stop, sometimes (not every time) the clutch will grab extremely extremely early. I disengage the clutch like normal, but when I lift my foot, I feel the pedal come back all the way but the clutch grabs almost on the floor (Thus I stall out almost every time).
To me it sounds like the Master and Slave cylinders are about to go, but I'm worried that it could be something else.
What do you guys think?
EDIT:
Well I didn't flush the system. I only added because I ran out of time.
It isn't air in the system because it doesn't happen every time I disengage/engage. I'm debating whether or not to do it myself or bring it to a friends.
I'm bringing it to a friend to replace those though. I tested to make sure the clutch wasn't slipping (5th gear at low speed and punched it - no rise on the tach) so I think that is ultimately fine for now.
Anyone know where to get a spring compressor for the front coil over shocks? I would rather not spend a mint and have to buy one just for replacing the front suspension this once.
Thanks,
-Kevin
EDIT:
Thanks,
-Kevin
