as the title says, i need the most secure way to clone an IDE drive to a new SCSI drive
before i go and tell them i can do it, i need to make sure the data on the source drive can be preserved without messing anything up, just popping that IDE drive back into its orginal computer and have it will work just as it did before
the data is crucial to be saved since it is a pharmacy computer, and all patient files and programs need to be just as it was before the drive was cloned
cliffs:
SCSI drive failed in one of their computers, ordered new one
everything that was on the failed SCSI drive is on an IDE drive in another computer in the pharmacy
want to take IDE hard drive from other computer and put it in the tower where the old SCSI failed, and clone to the new SCSI drive without removing/tangling data up on IDE drive so that it can be replaced back into machine it was in and work as it did before cloning
OS: Windows 2000 Pro SP4
any specific program i should use? i have heard acronis is a good program to use, but unsure of what version to use(migrate easy or true image, etc).
if someone is able to answer me these questions, if you could, provide a set of instructions so i can do this job without ruining one of their computers?
THANK YOU SO MUCH!!!
cliffs:
