Is this ok to do, or is there any static problems that might be associated with using Transparencies as building material for ducts. I have a superlanboy and NFS-7 ver2 and want to isolate the psu exhaust from the cpu - ie the cpu's hot air goes out only via the aft 120mm fan.
I was thinking of bending the transparency once lengthwise to form a 90degree bend and then tape it to the 120mm fan and have it over and above the cpu area.
