After disabling 3 entries of "Windows boot manager" under UEFI in BIOS, now all i get is blank or black screen. Monitor doesn't even come out of power saving mode and keyboard caps lock / numeric lock lights are not coming up either.
As you can see i'm by no mean expert on motherboards, but i believe, this "HP OEM IPISB-CH Cleveland Pegatron", manufactured in mid-2011, do not have a full fledged UEFI, which I have found on many recent HP model. Where you could disable UEFI altogether. In this model, the only way you could do it is under "Boot order" menu.
So far I have tried different monitors, disconnected hard drives, removed memory modules, graphics card, CMOS battery, main power connector from motherboard, etc. few times...
The biggest issue i'm having is, how to clear CMOS settings. Here's the HP page support for IPISB-CH Cleveland:
http://support.hp.com/us-en/product...ries/5035344/model/5060998/document/c02668523
Under "Clearing the CMOS settings", there's a picture on how to change the jumper in order to clear settings but...
(1) there are two jumpers by default(which is shown in HP's and all other images of the motherboard elsewhere... while "how-to clear" pic displays only one ??
(2) there is no numbering (1 to 6) on the actual motherboard, but i think, i have tried all the combinations, with and without CMOS battery in place.
Actual photographs:
Few other things, i have played around with jumpers only after removing power cord, and then pressing the power-on button on the PC to drain power. HP tech support said the same thing as shown in "Clearing the CMOS settings".
Thanks a million in advance, any help is greatly appreciated.
Actual photographs:
