cleaning your LCD monitor
ayabe
7,449
Originally posted by: Todd33
50% rubbing alcohol, 50% water from what I have read.
Agreed, there are also special chamois-like cloths that you can pick up at BBY/CC that won't scratch, don't use something like a paper towel. Also, don't apply any pressure, be very gentle.
Ig
236
I just use a microfiber cloth. It's the same one I use for my glasses and my camera lenses. If the smudge/dirt is really persistant, I just add a little water. So far I've been able to clean everything I get on it, including the occasional bug guts (annoying little gnats in the middle of the night :p). Just have to remember to wash the mf cloth regularly.
hans030390
7,326
take a pen and draw over any smudges...try to push hard...
i'd clean it with some water (on a rag) and dry it with a towel...be careful though
Powermoloch
10,084
4
I USE PAPER TOWELS !! the very soft ones...add a little touch of isopropyl alcohol, not so fancy, just a light rub or dust off effect on the LCD while it's OFF.
apoppin
34,890
alienbabeltech.com
and you likely have tiny little scratches if you look closely . . . paper scratches plastic :p
:roll:
[of course, there are "paper towels" made from cloth that won't scratch]
TheoPetro
Banned
Nov 30, 2004
3,499
Originally posted by: gac009
anything that touches my monitor screen dies.
going allong w/ this idea i have actually attached a 8ft death ray to mine....it doesnt even get to come close to mine to die
Parkre
616
Hey, me too! I have the 3100 model rev.2, which one do you have? :laugh:
Crescent13
4,793
I rub hard for 15 minutes with a moist paper towel, I get the paper towel wet with water. I don't see any scratches, the monitor is clean and streak free.
MBrown
5,726
35
Ok. This stuff on my LCD looks like tis hard to get off. It looks like im going to have to scrub. What do I do about that?
potato28
8,964
I use dog poo, oil, and my guitar string cleaner cloth(very hard) EDIT: or $1 american bills/ new $5 canadian bill
xtknight
12,974
I've cleaned my LCD just like a CRT: use a damp cloth and apply as little pressure as possible. I don't have any issues with it.
Polish3d
5,500
I set off a small yield nuclear device next to the
No I use water and a glasses cleaning cloth
akugami
6,210
2,552
Some really soft lint free cloth, like those glasses cleaning cloth. I usually use alcohol to cut any grease and grime that may have accumulated (I eat at the computer table a lot, and sometimes these tiny bugs are attracted to the LCD and I have to squish the annoying bastids). Don't use any abrasive cloths or towels and definitely don't use any abrasive cleaning products like bleach and acetone.
2Xtreme21
7,044
Ammonia wipes do the trick for me. They're anti-static wipes that can be found at any wal-mart type store.
UltraWide
793
just use 50% alcohol and 50% distilled water like other posters mentioned + a lint-free cloth.
