Turbonium
Quite some time ago, I was cleaning the back of my PC case with some water+cleaner and paper towel (it had caked-on dust like you wouldn't believe). I somehow managed to get a bit of the cleaning solution into the PSU (the mist from the spray bottle). The computer was off at the time, so I just let it dry for a few hours, and hoping for the best, powered it on.
Luckily, nothing went wrong, and I used the PC for years afterwards without issue. The rails were fine also.
I did, however, notice a bit of tarnishing on the components inside the PSU (what looks like spots of oxidation, or "rust"). I figure this may have been due to the cleaning solution.
Did I shorten the life of my PSU? I was hoping to use it in a new build, but if it's possibly ruined somehow, I won't.
The PSU is a 430W Seasonic S12, if that matters. No bulging capacitors from what I can tell (I wouldn't use it if there were).
