Cleaning plexi during installation.
jspeicher
1,904
Once you drill a fan hole (if you're installing one) into a peice of plexi for your case window, is there anything in particular you can use to clean the plexi itself?
If you have tape residue on it or something - just water or goo gone? Does rubbing alcohol have any effects on plexi?
