Cleaning paper rollers on HP
Skel
6,218
679
I have an old hp that sometimes doesn't want to pick up the paper, is there a good way to clean them without tearing it apart???
Thanks in advance for the info!
Skel
XMan
49
Can you take the paper tray out? I use a citrus oil rubber restorer and a cotton towel. Just reach in there and clean the rounded side of the rollers - they should be shaped like D's. You should be able to spin the feed shaft freely in one direction.
Skel
6,218
679
I'm sorry, like a complete idiot that I sometimes am, I forgot to mention what kind it was..
It's an old HP Deskjet Plus..
Thanks for the info..
SKel
billyjak
The new Ink refills come with a CD and cleaning strips, you print out a test sheet, put the cleaning strips on the location specified and pront with it. I have these for my old 660 deskjet.
