Cleaning off compound from HS and CPU
yadda
What is the easiest way to clean off the Arctic Silver from the Processor and Heat sink. I have just replaced my motherboard.
Thanks
Y
Originally posted by: Pohemi420
If you use Isopropyl alcohol from a typical store, make sure you get the >90% type. 😉
I use 91% Isopropyl alcohol. When all else fails I have 100% acetone for just such an emergency.
