Cleaning gasoline and engine oil - soaked items?
fuzzybabybunny
Moderator<br>Digital & Video Cameras
Moderator
Jan 2, 2006
10,455
35
I have a paramotor in my car and the fuel tank developed a bit of a leak overnight at one of its fuel outlets. As a result, my sleeping bag, down jacket, and two backpacks are now soaked in a 50:1 mixture of gasoline and two-stroke motor oil.
Um.... I have them sitting outside for the gasoline to evaporate out. How long do they need to sit for? They're all super-absorbent items.
And how do I clean off the two-stroke motor oil that won't evaporate?
twinrider1
4,096
64
They use Dawn on live critters caught in oil spills. Probably take a few soak/rinse cycles.
crashtech
10,695
2,294
I'd ask a professional dry cleaner how to proceed. Not that their processes would be suitable, but they might have some knowledge, being in that business. I'm told that several wash cycles with extra detergent and some ammonia will help cut the film and allow the heavier parts of the hydrocarbon mix to wash away.
Gardener
770
561
Dawn is worth trying, however I keep around a gallon of "Oil Eater" for stains on clothes, for part degreasing, engine degreasing, and the grill. Its the best water based grease remover I've found, I've added it to the wash, and used it as a prespray.
Although I have seen oil stains on synthetics that are married to the fabric and will not be removed. Perhaps taking these items to the dry cleaner where they dunk them in a petrochemical solvent is the way to go. They could steer you in the right direction.
MongGrel
38,466
3,067
121
I'm not a professional as far as dry cleaning.
Dawn was also the first thing I thought of myself.
But that would involve a lot of additional work, talking to a dry cleaner would be your best bet in this case I imagine.
Kaido
Feb 14, 2004
52,076
7,467
Could always soak your logs in wood...
twinrider1
4,096
64
I'd ask a professional dry cleaner how to proceed....
Yep, reminds me of a story my dad told me. He was a lead man at North American Aviation. They had tanks of trichloroethylene to degrease airplane parts. Guys would hang greasy shirts above a vat and the vapor from it would clean the shirts. Wicked stuff; even then they'd only let you work around it for 6 months. Not sure if it is even legal any more, but dry cleaners have similar stuff around.
sdifox
100,982
18,119
Just buy new sleeping bag and down jacket. They will lose most of their heat retention the moment you do degreasing on them anyway. You could try refilling I guess but I am not sure how good the down you get and how repairable jacket and sleeping bags are these days.
Jimzz
4,399
190
Just buy new sleeping bag and down jacket. They will lose most of their heat retention the moment you do fegreasing on them anyway. You could try refilling I guess but I am not sure how good the down you get and how repairable jacket and sleeping bags are these days.
Yea unless its a super expensive one just replace it.
