cleaning flat-panel monitor
Originally posted by: Rhombuss
If you know someone who works in lab, kimwipes do the trick for me 😉
Kimwipes with what? Kimwipes are dry.
Since the cover is plastic only, I am hesitant of using solvent.
Swiffers and windex on a paper towel.Don't spray it on the monitor but on the paper towel and don't use so much that it runs down the screen😉
Hey...
Don't use any cleaning solutions on the display...might damge it. The best way is to get your self a good MicroFiber towel, and add a mist of water to the towel. Not the Display. If you don't have a MicroFiber towel, just use something that doesnt lint. Sweep the display with the grain not against it.
Well thats about it. Laters.
I use a cloth used for cleaning eyeglasses. Those generally work pretty well (microfiber cloths are the ones that Sunglass Hut sells).
Heheh I do too, and the spray they give you. Works great. If it won't damage $300 Revo polarized lenses, should be fine for my monitor 🙂
Chiz
