IndyColtsFan
I've got a few downspout extensions that go underground and out to drains in the yard. They've worked well in the past but they seem to be clogged, possibly by leaves but more likely, roots. I need a way to easily clean these myself. They're the black corrugated pipe like this:
In total length from the downspout to the drain is no more than 15-20 feet or so and I'd wager (though I could be incorrect) that both are clogged in the last 6-8 feet of the pipe because that's the section under the lawn (from there, they go under a patio so roots would be much less of a problem).
What's a good tool to use for something like this? I had a guy quote me $700 for two hours of using a water jet in them but since this may have to be done every year, I don't want an annual $700 cost and would prefer to do them myself if possible.
Thanks
EDIT: Thought about trying an auger like this. Do you think it is safe for that kind of pipe?
Thanks
