Cleaning an LCD
Koudelka
I just bought a NEC Multisync LCD1765. Sometimes people in the family might touch the screen even when i tell them not to and smudge it a little, whats the safest way to clean it and get dust off as well?
I use a special LCD cleaning liquid and special fine cloth made by Peca that I got for my digital camera,does both my digital camera LCD back screen and my LCD monitor.
No smearing and does not damage my monitor 🙂.
Link (note UK website).
Btw I would caution about using alcohol,it could remove the special coating on the LCD screen,damp cloth( clean fine lens cloth) with water(distilled water would be best) for cheap safe solution.
Originally posted by: earthling30
I use alcohol to clean my Laptop screen. It does really well for that. Put a little on a paper towel and wipe away while it's off. HTH
HTH?
I picked up an LCD cleaning kit from my local Apple store. I can't remember the maker but it comes with a spray bottle and the spray is thicker than water so it doesn't drip. I just spray it directly on the LCD. It comes with special towels as well. It works great and doesn't leave streaks.
I've read that a 50/50 mix of alcohol and water is ok but I'm not certain. I tried it once and it did leave streaks, not to my liking but I haven't noticed any lasting effects.
