Cleaning an LCD monitor?
Croton
Banned
I have these wet and dry cleaning wipes that are used for the CRT...
Can i use them to clean an LCD monitor?
If no, then what is the best way and safest way to clean an LCD?
Thx
PURE ACETONE !
NO, No, just kidding. Just a mild cleaner and very soft cloth. I just dampen a cloth with water myself. What does you owners manual suggest (OH, Horrors, Read?)
My method:
1. Extend index finger.
2. Open mouth and stick out tounge.
3. Make the two contact.
4. Gently place finger on screen.
5. Wipe vigorously.
Yes, on my LCD and CTR I do this. 🙂
If you want to get fancy:
6. Place finger back in mouth.
7. Repeat.
croton, when u clean your lcd screen w/ the wet and dry towel that u use for CRT monitor, does it leave any residue on your lcd screen?
<< My method:
5. Wipe vigorously.
7. Repeat.
Gross after wiping all that dust on your finger you lick it again????
Nasty....
<< My method:
5. Wipe vigorously.
7. Repeat.
Nasty....
If you think that is nasty you should see how he wipes his ass.
