Clean an air filter on a car.
yobarman
11,642
I own a 95 Maxima and recently the car has been growing increasingly loud as it runs. Not any vibration or anything, but the engine just growls louder than usual as i move along. It's pretty sweet, but I don't think it may be good for the car.
I filled up today and realized im getting about 3mpg less than my previous fill up. This could be due to less highway driving, but also to the fact that i havent cleaned the air filter since i bought the car 3 years ago. Since i moved to denver, i realized that it is incredibly most dusty around here than back east.
I have this filter on my car, and it says to clean it on a regular basis. What is the best to go about cleaning the filter for optimal and safe results?
GrammatonJP
1,245
yikes.. they sell cleaning kits.. you're suppose to spray on cleaner, rinse from inside out only, dry and reoil.. takes a few hour..
yobarman
11,642
Originally posted by: iamwiz82
Have you checked for an exhaust leak?
No, but i'm pretty sure there is one. The car has been falling apart slowly but surely, but its still going strong :D
GrammatonJP
1,245
http://www.se-r.net/engine/intake_install.html
if you want the cleaning kit, let me know, i got two of them for free.. do not use kn anymore... one is brand new.. unused. the only thing is i dont know if you can ship that stuff by air.. its aerosol can
I picked up a K&N Filter Recharger Filter Care Service Kit (# 99-5000) for $10.99 at PepBoys. You can pick it up at most auto parts stores. Don't be embarassed to ask! It wound up being behind the counter where I went.
I went by the K&N directions on the box. There are only a few things I wanted to mention.
Make sure that when you're spraying water and cleaner that you get each fold.
Make sure you rinse and spray water and cleaner from the inside-out. This way no dirt gets further into your filter.
Make sure the filter is dry of any water before installing.
The whole process takes a little while so leave some time. Do it some time when you're not planning on going back out for a while. Also, make sure that when you reinstall the filter that you're careful! It took me 3 full days to clean my filter because I wasn't careful and I was in a rush. Next time, I plan on bettering that!
yobarman
11,642
ROFL thanks guys :eek:. I feel like a negligent parent. I will hit up the auto parts store today
