- Feb 2, 2009
- 14,003
- 3,362
- 136
While i was preparing my APU Hybrid review, I came upon a strange behavior of the Civilization Beyond Earth Hybrid performance when both the APU and the dGPU were overclocked.
When both the APU and dGPU are operating at Default clocks in Hybrid Cross Fire mode, the performance is faster than when both are Overclocked at low resolutions of 1280x800 and 900p.
At first i though it was a throttling problem due to high temperatures. But even with a Water cooler on the APU and an extra fan above the motherboard VRMs the performance was the same as before, sub par against the default clocked Hybrid CrossFire.
Sustem hardware and steup
APU : AMD A10-7850K
Motherboard : ASUS A88XM-Plus
Memory : 2x 4GB 2133MHz Kingston Genesis 11-12-11 1.65V
HDD : Seagate Barracuda ST1000DM003 1TB SATA-6
PSU : Thermal Take TR2 380W 80plus Bronze
dGPU : GigaByte GV-R725OC-2GI (R7 250 2GB DDR-3)
GPU clock @ 720MHz
GPU Mem @ 800MHz
Second dGPU for reference at 1080p Medium settings
Gigabyte HD7790 1GB GDDR-5 OC
GPU Core @ 1075MHz (R7 260X is at 1100MHz)
Memory @ 1500MHz (same as R7 260X)
AMD Catalyst 14:12 Omega
Windows 8.1 64bit
Overclocking APU
CPU Core @ 4.35GHz
iGPU @ 856MHz
DDR-3 @ 2424MH 11-13-13
Overclocking R7 250
GPU @ 855MHz
DDR-3 @ 830MHz
For the review I have used the in-game benchmark with Mantle (except for the HD4600).
At 1280x800 Hybrid Cross Fire scaling vs A10-7850K iGPU = 83,44%
As you can see from the graph, when Overclocked in Hybrid Cross Fire mode the results are inferior than at default clocks.
Overclocked TimeFrames are worst as well if you compare them against the Hybrid Cross Fire at default clocks.
A10-7850K iGPU with Mantle
APU : AMD A10-7850K
GPU clock @ 720MHz
GPU Mem @ 800MHz
Windows 8.1 64bit
Overclocking APU
CPU Core @ 4.35GHz
iGPU @ 856MHz
Overclocking R7 250
GPU @ 855MHz
DDR-3 @ 830MHz
