Cisco TelePresence SX 80 Wireless Microphone
olds
50,127
781
We have a Cisco VTC system that has corded microphones. I want to go with cordless. What do I need to have to make that happen?
I assume something that plugs in the audio port that has cordless microphones, but no idea what that would be.
thecoolnessrune
9,673
583
It depends on what you're connecting. The audio ports on the SX80 are Euroblock 3.5mm terminals, which are generally used for connecting audio setups with little to no movement (they aren't designed for repeated plug/unplugs unlike XLR).
The Euroblock port for each mic goes left to right as +, -, Ground, Mute. Armed with that, you can connect to any microphone system using the proper conversion adapters (such as Euroblock to XLR). You can then work with your vendor to purchase a Wireless Microphone System that has the appropriate connectivity.
