JoLLyRoGer
This is my first time setting up a MARS before. So far so good, I've got all my switches, routers and two ASA's communicating along with their IPS's. Here's the problem, I like to keep backup's of my config files and so far I've not found a good way to do this with the MARS.
It appears Cisco took a different approach to IOS this time. MARS appears to be running a Cisco-bastardized stripped out Linux forked from RedHat. The problem is it doesn't respond to a lot of typical IOS commands, even worse it dosn't respond to a lot of standard Linux commands either. This is a different animal indeed.
So....
How do I do the equivilant of a normal 'copy run tftp:' command and/or 'sho run/sho tech'.
Thanks!
-JR
So....
Thanks!
-JR
