Cisco dude help...
Vegito
access-list 101 permit tcp host x.x.x.x eq ftp-data host y.y.y.y gt 1024
x.x.x.x remote host
y.y.y.y local host
this way I limit FTP data only to specific host outside and specific host inside..
my question is say I need to goto a range of x.x.x.x/24, how do I specify that or it's not possible ?
I know you can range a port like range 1024 - 4096, but can you range a list of ip address to goto ?
<< access-list 101 permit tcp host x.x.x.x eq ftp-data host y.y.y.y gt 1024 >>
this statement says "allow source x.x.x.x-FTPDATA(20) to y.y.y.y-higher than 1024"
to use a range you need to get familiar with wildcard masks. instead of using the keywords "host x.x.x.x" you would use a address and wildcard masks.
10.10.10.0 0.0.0.255 - that says any ip address in the range 10.10.10.0-255
10.10.10.0 0.0.0.63 - that say any ip address in the range 10.10.10.0-63
here is the full command syntax:
access-list access-list-number [dynamic dynamic-name [timeout minutes]] {deny | permit} protocol source source-wildcard destination destination-wildcard [precedence precedence] [tos tos] [log | log-input] [time-range time-range-name]
maybe describe exactly what you are trying to do and I can provide a good one.
command reference
better linky
