I doubt you can do that on an entry-level router. I have a Pix501, which also comes w/ integrated 4-port switch and the ports can't be individually configured. I assume it's the same for 831.
I know you can configure the 831 switch ports with different ip addresses or set up a dmz. If you can configure the ports they should support QOS as well.
Funny thing I just had an 831 dropped off at my desk and I had to throw a config on it. All the switch ports do indeed have the same commands available to it that E0 & E1 does. So you are good to go!
