First, a little background; I installed a PC in may car to play mp3s, all the details and pics are here: http://www.mp3car.com/usersites/bombboyer
The electronics question:
What I have now is a switch for my PC mounted in the dash, and an inverter in the trunk. The inverter's low voltage alarm goes off when I crank the car, so I installed flip switch in the glove box so I can give the inverter power after I crank the engine, then I hit the PC power button
I want to replace this system with one that is more efficient. When I crank the car, I want a 5 sec delay before the power to the inverter is connected. Then, when I turn off the car, I want power to the inverter to be cut.
There also needs to be an "override" flip switch to enable or disable this whole system, so I can run the PC with the car off if I want to.
I need your electronics expertise to design and build this circuit. If I'm not being clear, LMK.
