- Nov 9, 2000
- 5,388
- 1
- 0
i'm looking to add florescence shop lights to my garage. i believe the breaker is 15 amps. the lights are 2 tubes of 32w each. how many fixtures can i safely install, total? i don't have that many receptacles in the garage, how many can i safely install per receptacle if i use those multi socket converter things.
i thought 15amps at 110 volts = 1650 watts, which means 25 light units, but that doesn't sound right.
thanks
thanks
