Ciphersuites, more mixed messages than my Xgf
Acanthus
19,915
ostif.org
I've been looking into manually managing ciphersuites and I had a few questions that i'm hoping someone up-to-date on cipher security can answer. The articles i have read have conflicting and dated information all over the place.
#1: It is my understanding that as of OpenSSL 1.0.1e (or TLS 1.2) that block ciphers (specifically AES and Camellia) are no longer vulnerable to cache timing side-channel attacks. Is this correct?
#2: Knowing #1, it is now safe to say that block ciphers in CBC mode are once again safe, even though that there are a few known weak attack vectors that simplify them slightly.
#3: SHA1 has known collisions, SHA2-256 is the new minimum known secure standard, correct?
#4: For all normal intents and purposes RC4 is completely broken. Don't use it. Is this a correct blanket statement?
#5: Ephemeral keys are are the only way to achieve perfect forward secrecy using OpenSSL or TLS 1.2, correct?
And finally a question: Is there a mathematical or probability reason to consider GCM safer than CBC after the current round of OpenSSL updates?
Thanks in advance guys, this is a lot of BS to shuffle through via google and wikis.
smakme7757
1,487
I have RC4 running as the highest priority on my webserver. Most banks have also switched over to RC4 primarily due to the BEAST attack.
So I would say number 4 is untrue.
SHA1 has been attacked successfully under certain circumstances, so 256 is best for new systems and implementations.
Acanthus
19,915
ostif.org
BEAST doesn't work in TLS 1.2.
Number 4?
https://en.wikipedia.org/wiki/RC4#Security
https://community.qualys.com/blogs/securitylabs/2013/03/19/rc4-in-tls-is-broken-now-what
http://www.isg.rhul.ac.uk/tls/
The most current documentation i can find says that RC4 is dead again, and that CBC ciphers are again safe.
unokitty
3,346
Cryptology has many subtle aspects.
For example, if you look at NIST"s Policy on Hash Functions, you would find:
SHA-1: Federal agencies should stop using SHA-1 for generating digital signatures, generating time stamps and for other applications that require collision resistance. Federal agencies may use SHA-1 for the following applications: verifying old digital signatures and time stamps, generating and verifying hash-based message authentication codes (HMACs), key derivation functions (KDFs), and random bit/number generation. Further guidance on the use of SHA-1 is provided in SP 800-131A.
Since NIST ended the SHA-3 Cryptographic Hash Algorithm Competition on October 2, 2012, when it announced KECCAK as the winner of the competition, and the new SHA-3 hash algorithm, you may also want to look into the process they employed to develop the new standard.
Best of luck,
Uno
Acanthus
19,915
ostif.org
Best of luck,
Uno
Thanks for the info!
I was aware of the existence of SHA-3 but now it is so bleeding edge that it isn't supported by browsers yet.
