Chronicles of my x2 3800+ o/c (first ever o/c for me)
goobernoodles
1,820
Ok, well... I can't seem to get past 210ish HTT. This is my frist time overclocking. I clocked my ram down to 133mhz, set the HTT frequency to 2.5, set the cpu ratio to 5. Could this be an issue with the ram? I have 4x512mb GeIL value ram... Also the temps are 33-35c idle. XP90 with a thermaltake silentcat on it. The motherboard is a MSI K8N Neo4-F.
EDIT: This was the original post, solved that, keep reading.
saltedeggman
3,775
4x512 would be the problem... my guess....
try running in 2x512 setup to see if it helps
also relax all the timings on the ram.... to reach max HTT
TankGuys
1,080
That's definitely odd. Yea, try cutting down to 2x512.
Sometimes you just get bad boards... hopefully yours isn't one of them!
goobernoodles
1,820
Ok... now I'm getting Super PI and Prime errors almost instantly... CPU temp is 35 idle... and goes up to 40ish... Should I be getting errors at this low of a temp??
goobernoodles
1,820
Eh, yea, I spoke too soon, I upped it to 1.4v and its stable so far. Is it ok to use 2 different programs to test the cores? And is 47c too hot at full load?
I have Prime95 on one core and OCCT on the other. So far so good.
goobernoodles
1,820
Well 15 min so far. I'm gonna go over the gf's for the night. Hopefully I'll come back home to see no errors... that, and I get a 7800gt tommorow. :D
goobernoodles
1,820
Well, I'm not entirely sure what happened last night, had a power outage. >:/
Regardless, I got my 7800gt today, so I reformatted and I'm testing again. I can't seem to open 2 instances of prime95 so I'm using Super PI and Prime95.
I'm using MSI's CoreCenter for temp monitoring... and there are some strange things going on:
1) vcore (set to 1.4) fluctuates from 1.36-1.39
2) the program constantly shows the speed its running at, and it fluctuates from 672mhz (223htt x 3.0) to 2400mhz (240 x 10) to 4129mhz (242 x 17)....
What the crap?
biostud
19,900
7,008
run prime95 as: "prime95.exe -a0" and "prime95.exe -a1", it will open two instances, one for each CPU.
goobernoodles
1,820
I just realized that I had the voltage raised by having "extra cpu voltage +3.3%" instead of actually setting it to 1.4... Is this not preferable?
Doctorweir
1,689
A little jumping on the voltages +-0.03 is normal, depending on the stability of your PSU, Mobo circuits, etc.
I would prefer to actually set the voltage...no percentages...
When starting to overclock make sure to disable Cool n Quiet in the BIOS to prevent Windows from fooling around with multipliers and voltages. A good CnQ config is for later... ;)
