Chronicle of an AMD APU Budget Machine Project
Aug 11, 2008
10,451
642
Just one question
Why the GPU memory matter?
I have amd sapphire 7770 with 1Gb of ram playing in 1920 x 1080 resolution monitor,
Is it OK ?
You should be fine. You need a lot of graphics memory to load the textures or whatever at high resolutions and image quality, but the 7770 is probably not fast enough to use more than 1gb. Actually I am running at 1080p with a 1gb 7770 and it will run everything, but for more demanding games I have to turn down some settings, especially AA.
borgonzola
4
How do you allocate system RAM to the GPU? I have the same motherboard and APU as you, and I can't for the life of me figure out where the setting is; it doesn't seem to be an option in the BIOS.
tornadobox
2,081
In the BIOS, go to Settings > Advanced > Integrated Graphics Configuration > Integrated Graphics Devices and select Dual Graphics (yes, counter-intuitive). This opens up Integrated Grahpics Share Memory where you can allocate 32MB, 64MB, 128MB, 256MB, 512MB, 1GB, or 2GB.
bomuaz
can you explain this to me more
is it mean in high end graphics cards i need more than 1 gb because it can run high games or it depend on which game you play with what resolutions ?!!
SPBHM
5,076
440
if you use higher settings (resolution, MSAA), the games will tend to use more memory, since your GPU/memory is not as fast as let's say a 7950, you might not be able to use these higher settings (with acceptable framerate) for other reasons and not memory size, so it's a lesser problem, if you look here, even with a faster card and high settings 2GB is not necessary in most or many games even in 1080p,
you should also consider size vs speed (bandwidth) for the memory... slower but with higher size, normally is a bad decision,
tornadobox
2,081
Updated with a start at consolidating pictures, and a more detailed fan vs. fan graph depicting noise level delta as well, along with CPU-z and GPU-z readouts at stock APU settings.
bomuaz
I tried to build like your project but I came with around 450$ I tried every where
Amazon , newegg..etc and that without the water cooling system!! ..
tornadobox
2,081
For the same components I listed (same part numbers)? Are you in the USA?
tornadobox
2,081
Messing with voltages to stabilize OC'd system performance, right now the max I'm getting is 105MHz FSB without crashing.
Increasing the FSB to 106 (even when going back to the default GPU Clock and lowering the multiplier to 39 yielding in a lower overall GHz output than my 'stable' 105 x 42) crashes the system.
I think I might have some room for a CPU-NB Voltage increase, since if I remember correctly it used to be tied in to the CPU Core Voltage (which I currently have at 1.499500v) back in the day. However, I'm not totally sure if increasing the CPU-NB Voltage above 1.35v is safe, so if anyone knows, please chime in!
tornadobox
2,081
Updated the original post with the first of the overclocked benchmarks (3DMark11). An increase of 240 points, I think that's pretty decent!
zootedd
127
Just one question
Is it OK ?
Yeah, I don't think the 7770 would benefit too much from 2gb anyhow. Especially if you are not using demanding aa settings.
tornadobox
2,081
Tweaked a bit more, got the RAM to run @ 2133MHz, increased the 3DMark11 score (+254 points from stock), and updated with some OC gaming benchmarks.
