Hi! Im building a new rig.
My priorities are:
- It must be future proof as I upgrade infrequently.
- I prefer the most bang for the buck.
- Good quality of the components.
- It must be quiet (no water cooling).
- Applications are primarily gaming (the latest games).
These are the components Ive looked at so far:
CPU - Intel Core i5 3570K 3,4Ghz (Ivy Bridge)
Motherboard - Asus P8Z77-V
Graphics - ASUS GeForce GTX 670 2048MB DirectCUII TOP
RAM - Corsair 16GB (4x4096MB) CL9 1600Mhz VENGEANCE (low profile)
PSU - Corsair AX 750W 80+ Gold
Case - Fractal Design Define R4
CPU Cooler - Noctua NH-D14
Now for some questions and thoughts.
1. Regarding the processor, Ive understood that you get more bang for your buck with the Core i5 3570K instead of a Core i7 3770K. As we know, 3770K Hyper not affect gaming that much, if anything at all. But how will the situation be in 3-5 years? Maybe it's worth it to spend a little extra on a processor with HT?
I will also in the near future (1-2 years) run SLI, and then maybe HT is not a bad idea. I read somewhere that a 4-core processor with HT can better "manage" an SLI configuration?
2. In the case of the CPU cooler, I chose the Noctua NH-D14 because in the future Im going to overclock the processor. Have also read that Ivy Bridge have some heat problems. Is this cooler overkill? Perhaps there are other, cheaper that works well with my configuration, and will also work when I overclock?
Grateful for all answers, thanks in advance
My priorities are:
