I only found out about the awesomeness of Neutral Density Filters this week (!) and now I feel I can't live without it
! (Yes, I know I sound like Calvin there).
Then I realize that my circular polarizer was bought for the kit lens and I really need to get one sized 67mm for the 17-50mm lens that I nowadays use as a walk around.
So, is there a priority between these two types of filter - or should I get both? As you can infer, I have not used the polarizer very often in the past year, and need to, seeing that I shoot landscapes a lot. And I need to read up on how exactly the ND filter is used.
And while we are here, what other types of filter are out there that are used often?
! (Yes, I know I sound like Calvin there). Then I realize that my circular polarizer was bought for the kit lens and I really need to get one sized 67mm for the 17-50mm lens that I nowadays use as a walk around.
