Hi,
I'm thinking seriously about buying a laptop next friday (My local shop will be giving a 10% discount over everything).
So, I went there to take a pre-look on the machines around, and for the price of about 1500?, I found the following laptops:
1# Toshiba Satellite M30X-144 - (1499?)
Pentium M745 1,6Ghz (Centrino 2Mb cache - and probably 400Mhz FSB?)
512Mb (Expandable up to 2Gb)
ATI Mobility Radeon 9700 128Mb DDR
80Gb HD
DVD+/- RW /Double Layer
Wireless Lan 802.11b/g
15" Wide TFT Truebrite XGA / Resolution 1280x800
I think it also has memory card reader ...
(... don't have all detailed specs with me ...)
2# Acer Aspire 1694 WLMi - (1599?)
Pentium M760 2,0Ghz (Centrino 2Mb cache & 533Mhz FSB)
ATI Mobility Radeon X600 128Mb DDR
80Gb HD
15,4" WXGA CrystalBrite / Resolution 1280x800
Memory card Reader (MMC,5D,MemoryStick,SmartMedia)
Oh, this laptop has bluetooth.
What I need? Basically a computer to work on. I do programing in WebSphere, and most probably will do some in .Net. So I'll have to buy a machine with at least 1Gb ram.
Also it would be great to play a bit, at least while the performance of the laptop is acceptable for the game requirements.
I'm interested in a good looking screen. I believe the Toshiba TrueBrite technology is great, maybe better that Acer's CrystalBrite ... or maybe not ... don't have experience with them. And looking into the screens on machines turned on 24 hours a day (almost) with the shop's light and with changed contrast/brightness settings can be deceiving ...
So my questions are:
a) 9700 vs X600? What would be the best? I know X600 is a more recent technology, but 9700 was the top ...
b) Acer has 533MHz. Is it the top at laptops? Doesn't the toshiba machine have 533 FSB also?
c) Can 2Gb ram do any practical performance increase that make it a better choice?
d) So, which one would you choose?
Positive Points:
- Toshiba has a nice looking screen;
- Acer has a friendlier keyboard (for me at least ... I like a Ctrl on the right side of space, for example)
- Maybe Acer is a latter/better technology?
Negative Points:
- Maybe Acer's screen is not as good;
- Toshiba has a keyboard layout I must take some time getting used to ...
Any help, tips on choosing/looking into a laptop, etc ... will be of great help! It's a big investment! And I don't plan to make a mistake (I hope 🙂)
Thanks
80Gb HD
80Gb HD
Positive Points:
Negative Points:
Thanks
