Hi,
I'm working on a project in which we're building a fully automated robot for a competition. The robot requires image processing, audio processing for navigating, apart from using other sensors such as GPS/compass. The robot also has motors which have to be driven. Now, this entire thing has to run on batteries and the competition rules specify that the robot must have a mass <30kg.
I wanted to use a full motherboard and an AMD Athlon for the computing. The reason for using this is the expansion capability and the familiarity that such a combination offers. However, the power consumption and current draw worries me. I wanted to know, what would the power consumption of just the processor, the motherboard and 256MB RAM would be. I ran a decent system using the nForce board with the onboard graphics and HDD, CDROM on a 300W power supply. Would I be correct in assuming that the three should run <200W or maybe <150W? I see that the 3000+ consumes 74.25W and draws 45Amps. Would Li-ion batteries be able to handle that kind of load?
Also, which chipset should I use? I was planning on using the nForce2 400 without the onboard graphics and instead just plugin a flimsy PCI VGA card to reduce the power consumed by the on-board geforce. This also strikes me, can I boot up a system without a graphics card being present? If so, then I can remove the PCI card to reduce the power consumption and the weight (not much, but still...everything counts). I'm also thinking of using a mini-ATX board. Would there be a difference in the power consumption of full ATX n mini-ATX?
I know the specs are really high, but the thing is that this competition happens every year and well, I'd prefer just one investment in the hardware for a long time, coz i don't see my project moving to 64 bit, well not just yet
OR
At the other end of the spectrum, could I just use a motherboard/processor combination of a laptop? I don't think that should be a problem and it would sort out the issues like power consumption and stuff. However, wouldn't the advantage that was present in the desktop combination (4-6 PCI slots = great degree of upgrade scope in terms of ports, sensors etc.) be wiped out? Also, where can I buy a new mobo n processor (of the laptop, ofcourse)?
Well, that's a lot of questions. I hope you guys can help. And just one last question, do u guys know of any single board computers which offer a decent scope of upgrading and around this much processing power? Thanks
Cheers,
Jimmy
OR
Cheers,
Jimmy
