Chipset Fan
Killeruk
I have a ECS K7S5A mainboard and I was wondering if I need a fan on my chipset? Also I have installed SiSoft Sandra and on the motherboard information it says my system temp is 33 C is this normal? Thanks for any help.
Lord Evermore
9,558
The system temperature is dependent on the temperature of the room the computer is in, along with the airflow of your case. 33C isn't anything to worry about, although a lower case temperature means cooler air blowing on the CPU heatsink; but 33C really isn't going to make your CPU any hotter. As long as your CPU is maintaining a good temperature, don't worry about the case temperature too much.
Your chipset doesn't need a heatsink with a fan. SiS chipsets don't get very hot, and even the faster chipsets from VIA or nvidia don't need a fan, as a large heatsink is plenty to cool them (and the SiS735 is fine with the small ECS heatsink). Fans are just a gimmick so that board makers can make more sales to people who think they need "extreme cooling". Only if you're overclocking a whole lot will the chipset get any warmer than a heatsink can handle.
