Chipset fan too noisy--solutions?
Chang10is
288
The chipset fan on my Epox 8KDA3J is making too much noise. Everything in my system is silent except for that one component, which is annoying because I just spent a good chunk of money on a Thermalright XP-90. What's the best way to solve my noise issue? Does anybody make a resistor that I can use for the 2-pin connector that this fan uses to get power from the board? Or do I need to buy a new chipset cooler altogether? If the latter is the answer, what are your recommendations for this?
harrkev
659
Can you set your BIOS to throttle the fan based on temperature? Some can, some cant.
If that fails, you can use a 3-pin-fan to 4-pin-molex adapter, and swap some pins to get 7V into the fan. If you already have the cable lying around, this is a free fix.
Mucker
2,833
Install one of these between the mb fan header and your chipset fan to slow it down. http://www.bestbyteinc.com/prodinfo.asp?number=FSC-ZAL-FM2
My Abit IC7 chipset runs stock 5800 rpm. I use the fanmate to run it one continous speed of 3000 rpm. I can't hear it anymore and things are plenty cool. The CPU fan exhaust blasts the NB sink too, so there is zero worry for me.
m :)
Toro 45
4,263
m :)
I did the same thing, works great:)
wisdomtooth
1,155
Ditto on my IC7, except I used a resistor. :D
Now my NB fan spins at a quiet 2500RPM and still keeps my NB cooler than if I used an NB47J.
HeaterCore
442
Hey Chopstick, that Zalman worked for you? I slapped one on my NF7-S and it became randomly unstable; sometimes wouldn't POST, sometimes would run fine for a few minutes/hours and then crash. I reseated the thing about four times, but it didn't do any good. I figured the chip was too big for that particular cooler (lots of exposed surface).
-HC-
xbassman
1,243
-HC-
Might want to check your case cooling. The Zalman needs airflow.
I have one on my NF7-M and never crash.
fAlCoNNiAn
27
if you have a extra 3 pin fan that you dont use at all, then you can splice the wires, and use a fan speed controller to regulate it. i did that to my 120mm, which had a 4 pin molex, works great.
Jhhnn
IN MEMORIAM
Nov 11, 1999
62,365
14,685
Operandi is correct, imo, lots of boards having that same chip have fanless sinks- the recommended zalman should solve the noise problem handily.
Chang10is
288
A couple of people have suggested just unplugging the fan. Do you guys think there's any risk in that? Seems like there might be since it wasn't designed that way--unplugging the fan would result in less dissipation than having a real heatsink on there without a fan.
HeaterCore
442
Yeah, there's a risk there. The active chipset coolers that come with most mobos are way too thin to function without solid airflow, and won't work passively.
-HC-
