- Apr 12, 2006
- 462
- 0
- 0
The NB fan on my msi k8n neo4 plat died on me recently. I ordered a Vantec http://www.newegg.com/Product/Product.asp?Item=N82E16835110103 to replace it based on acouple references.
I got the stock fan off without any problems. But putting the new one on brings a few up, and the fan came with no real instructions(just a small drawing on the back of the box). The NB chip sitis in the middle of the green larger chip, but there are other silver raised parts on the green section. The stock fan had what looked like 2 types of thermal compound on it. There was a thermal tape that ran around the edge, with a 'window(for lack of a better word)" around where the silver chip would rest and where a thermal grease was applied. The other smaller silver points have indentations on the tape.
What came with the Vantec fan is some strips of 3m thermal tape and a tube of thermal grease. What is my best option with the thermal compunds? And if the tape is the better option, does the adhesive side atach to to the heatsink and the 'melt on" side face the chip?
thanks in advance.
thanks in advance.
