papaschtroumpf
I have an older computer with a KT3 ULTRA MSI motherboards (Via KT333 based) and the fan cooling the chipset has stopped spinning some of the time, causing lockups.
when I start the mobo sometimes it spins just fine, other time I can see it move a little bit (1/8th of a turn or less) then stop. it seems that if I "launch" it with a pair of tweasers, it starts spinning normally most of the time.
As far as I can tell it's not a bearing issue, the fan appears to be spinning pretty freelye, so I'm guessing it's either a supply issue or a "motor" issue in the fan.
what are my replacement options? can I easily find a new fan? it there a resik that even a new fan might not spin right? would powering the fan from a separate supply (it's plugged in the mobo connector) be an option?
Thansk
Thansk
