Shoudl that apply to CPU heatsinks as well. I have a stock 4400+ heatsink and the fan blows away form the cpu. Should i switch it around so the fan blows onto the cpu? Least i think it is set up this way cause if i put my hand over the top i feel air blowing onto my hand
Yup, the wiring and spider (holds the hub (motor) in place) are on the output side - the intake side of the fan is normally wide open. Some heatsinks can work well with the fan drawing air thru the fins - but those are mostly the radial fin type. Closed bottom/vertical fin types usually require the fan to blow into them. But experimentation never hurts - try yours both ways and watch what happens to the CPU temps. I have my fan blowing thru a radial fin type heatsink toward the mobo because that also helps to cool the surrounding components - but I occasionally have to clean the fine dust off the windward sides of those components. No choice comes without a cost... TANSTAAFL!
