Hello!
I have a Chieftec APS-500S Psu which i use on an older P4 2.4 GHz S478 PC
This morning i've turned on the PC and after an hour some problems appeared:
all the components were receiving power (HDDs, coolers, even the CPU cooler etc) but it seems that the MB and/or CPU it's not powered.
i've tried tu turn it OFF and ON again but it's the same...
also with the PSU turned off the 5V SB is working (mouse and NIC are powered)
...and i know it's the PSU's fault because i've changed it and all is working...
as the PSU is out of warranty can you please tell me if this is something that could/worth be fixed!?
