Chieftec Dragon Mid-Towers w/window again for $19.97+S/H at TD
Shinare
273
$15 shipping to my zip code. :(
Edit: Should put +Shipping in title as well as TigerDirect
WT
4,816
60
That link is pointing to the front bezels ...... werd !
Try this link instead.
beany323
492
look nice enough i suppose... how is the quailty? (for 19 bucks worth i would think, huh) :confused:
Jun 9, 2004
77
Word of warning. Tigerdirect.com has a really bad reputation. There are plenty of others with this case for a buck or two more however you know what you are getting.
Mar 11, 2004
23,444
5,852
Well, I ordered 3 of these the last time and the shipping was only $26 for all three, and they arrived in 3 days.
Good cases (the ones I got were a little different, but still Chieftec and same chassis).
Nice price, and TigerDirect seems to handle selling these well, especially since there's no rebates.
tfinch2
22,114
BAD REPUTATION WITH REBATES. For everything else they are good. Check your sources newb.
se7en
2,303
TD is "ok" as long as there aren't rebates involved or a possibilty of having to return an item. These cases are nice but a bit on the bulky side and have most of the options you would want to DIY. I can stand on mine no prob without it flexing (no pics sorry) and ive been using this one on and off for a case for over a year.20 bucks is a good deal shipping might take away from that but if it goes for under 30 its a good price
Averox
651
Grrr
Now they have black and with a window. Oh well my case is going to sit in a corner anyways
jpeyton
Moderator in SFF, Notebooks, Pre-Built/Barebones
Moderator
Aug 23, 2003
25,375
142
FYI, these cases are awesome. Antec rebadges them and jacks up the price by $40+.
I ordered these from TD before and recieved them no problem.
Mephistokur
479
These cases are excellent. They are worth far more than 20 bucks. This is not cheap thin steel, this is good, thick, rolled edges and very solid design. This is the same as the Antec and Enermax cases, and are built like tanks. Please don't let the price fool you. These are some of the nicest, easiest to work with cases out there. The only caveat is that these are the STEEL cases are as heavy as a car. Don't LAN with them or you risk a hernia.
jabronidan89
159
I never lan, I never move my computer either. Perfect for me. I am so excited about this price, $50 is a big deal for me. THats what I am saving.
GprophetB
2,632
Bought the matrix case (black body with silver front mesh area thingy.. yeah)
anyways they shipped fast and i give them a 5 out of 5. Shipping was 13 dollars to my house ( and these things are fairly heavy)
Mac
728
Well, I held my nose and hit the "Submit Order" button and bought two of these. I haven't bought anything from TigerDirect in years...and for good reason.
But, these are really nice cases. I personally prefer this over the full tower dragons that were a hot item a couple of weeks ago. I already have one of these with the solid door (w/fan) and feel it is the best case I have ever worked with. Quality is topnotch. This ain't no aluminum strap-to-your-hip lan party box but a well built steel case that will give you years of service. If anything, I would prefer solid steel panels instead of the acrylic...more durable and less prone to scratches. But hey, for $20 + S&H, this is a winner.
uurda
162
I got one last round, and since this is my first build, maybe I'm just used to dealing with old Compaq machines when I say what a freakin' awesome case! Hardly need to pick up my screwgun with the tool-less fans and drive rails, plus locking window and front panel, four keys and healthy bag of screws. I'm thinkin' of ordering another cause I really don't need to experiment when something goes this right.
Edit:Got one red, one yellow. Aluminum frame fans w/LED from SVC.com for $6.99/ea that I'll swap out with the ones included in the case window, and put the stock case window fan in the front bay. It'll be a nice lookin' case running or not...
Dragonbate
324
Got a red one, and this is my first with a window :) Now I need a hot deal on a good power supply.
VirtualLarry
56,587
10,225
Ditto, I bought one of the full-towers at TD a week ago, and these cases are quite nice overall. (Heavy, too!) Just got my PSUs from Directron.com to match, ordered a black 520W SuperFlower ($33) and a 360W Chieftec ($20), those look like pretty-decent supplies too. (Chieftec case, Chieftec supply, how can you go wrong there?) Consider them recommended to drop in these cases, although their 12V amps ratings are a little on the low end to be used for an AMD64 system. I just have an Athlon and a mid-range P4 rig so no worries there.
I would have ordered a mid-tower too, but by then, only the full-towers were available. Still a worthwhile purchase, even if it is from TD, IMHO. (Can't believe that I'm saying that...)
jabronidan89
159
Anyone know if this case comes with 2 fans in the back. I know chieftec dragons usually do but does this one? No mention of it on TD, it doesn't show them in the picture, does show the side fan, hmmm. No problem if it doesn't come with fans, I will just order two from SVC in that case.
RamBusMan
324
Nice post OP! I missed out the 1st time but got 2 this time around. $74 shipped for California for 2 cases.
Moltnrok
167
I missed out the first time too on the Matrix cases which I would have preferred, but I'm jumping on this one. $59 shipped to KS for 2 cases.
