Numenorean
Why? Is the world going to end? Is the chicken going to explode? 😱
Yes.
Okay everyone who says to "cut into them to see" JUST STOP IT!
Yeah that's the dumbest thing you can do is just randomly cut into meat to see if it's done.
I've found that the easiest way for me to cook frozen chicken breasts is probably in the oven. It doesn't even require you to defrost the meat.
I wouldn't trust an opened raw breast in the fridge much beyond 5 days, but depending on how yours are sealed they might last a little longer.
For tasty, try chicken alfredo and chicken fajitas. Chicken alfredo is one of my favorite quick dinners -- I like it because the timing works out perfectly with angel hair pasta. Cut raw chicken into strips, then put 'em in a pan with a little oil. Put water on to boil. When the water starts boiling it's time to turn the chicken and heat the sauce (Five Brothers is good). Everything is done 4 minutes later.
Crazy good and only takes ~10 minutes start to finish.
Yeah, chicken and spinach is delicious.
It's a chicken breast, not Fillet Mignon, who cares if you gut into to check doneness.
I used to cut into my meats all the time, eventually I learned what it should look/feel like when done. I haven't touched a thermometer in years, all because I used to get a slit into meats to check doneness.
I boil my chicken breasts when they are frozen. They are done when they float to the top and sit there for a few minutes.
I thought quickly bringing up the temp of chicken is dangerous?
I'm probably wrong here, I just figured I'd ask. When I worked at Pizza Hut my boss freaked out on me for using hot water to thaw the chicken, stating that it would cause someone to get sick from salmonella or something.
because chicken is probably the worst (flavorless, moisture-retention, texture) protein out there.
cooking it well is not very easy--perhaps the most important issue being moisture. cutting open a chicken breast to check for doneness will instantly ruin it.
Believe me, I am very guilty of this. 😀
He's not thawing, he's cooking them in boiling water. But yeah, letting raw meat soak warm water to thaw will create a nice breeding pool for bacteria.
But it's ok to do if you are planning on cooking it after thawing it, correct?
If you're gonna soak in warm water to thaw, at least leave them in the package to do it. I still probably wouldn't do it. The only way I thaw stuff is by putting it in the fridge a few days before I want to use it.
Microwaving it ruins it, and soaking it in warm water is a recipe for bacteria.
Makes sense. I usually do thaw in a zip-lock bag, or the original packaging. In a hurry I've used warm water to speed it up though.
You must be cooking with gas. It takes 15 minutes just to get water to boil on my stove with the lid on, and pasta should boil for between 6 and 8 minutes minimum so it isn't crunchy.
There's no way you're not overcooking the outer portion if you're not thawing first.
Thank you for your meaningful contribution. Obviously, you're not skilled or passionate about cooking, so maybe this isn't the right thread for you.I recommend poking them while staring blankly at them. Do this until hunger forces you to eat fast food.
