Hi all I'm having a bit of a problem with a problem from my college chemistry assignment, here it is:
A cylindrical rod formed from silicon is 16.8 cm in length and has a mass of 2.17 kg. The density of silicon is 2.33 g/cm^3. What is the diameter of the cylinder? (Recall that the volume of a cylinder is given by pie*r^2*h.
I would appreciate a brief explanation also, not just the answer. Thanks.
