I understand that if we run an electrical current through water, it will decompose into its component parts (oxygen and hydrogen) according to the following chemical equation:
2 H2O -> 2 H2 + O2
I also know that this is an endothermic reaction (since the combustion of H2 is definitely exothermic). Because it is an endothermic reaction, theoretically, the temperature of the water that has a current running through it should go down.
However, I was thinking that even though the chemical reaction noted above would cause the temperature of the solution to drop, wouldn't the current itself send enough energy into the system to cause the overall temperature of water to increase? Essentially, my question is:
Will the temperature of water that has an electrical current running through it INCREASE even though the decomposition of water is an ENDOTHERMIC reaction?
Thanks!
2 H2O -> 2 H2 + O2
Thanks!
