CHEMISTRY...help. How do i do this?
ManBearPig
9,173
Write the net ionic equation for the reaction between Copper II Nitrate [Cu(NO3)2] and Sodium oxalate [Na2C2O4].
any tips? heh
magomago
10,973
14
While I actually spend quite a bit of time helping others....for this read your text book. This isn't hard by any means if you even looked at an example.
Kalvin00
12,705
^ What he said
Of course, I took chemistry last year and can't remember how to do this. Shows you how long that stuff stays with you, not even 4 months. :D
Chriscross3234
756
Yeah, it's a very simple problem as long as you know your solubility rules... give me a sec to work it out.
Learn the information, here's what I think is the right answer: Cu^+2 + C2O4^-2 = CuC2O4
neutralizer
11,552
Seriously, read your book. This is one of the basic examples of solubility. If you don't know this from attending class, you need to reevaluate what you're doing in class.
thesurge
1,745
Strong electrolytes + soluble= ionization---> cross out spectator ions and you have your net ionic equation.
ManBearPig
9,173
err, are those solids or liquids?
thanks
Dec 10, 2005
29,274
14,685
thanks
aqueous
thesurge
1,745
thanks
aqueous
:Q you really need to read your textbook.
soydios
2,708
Gawd, and I took AP Chem only just last year...
Summer is good at doing a low-level format of my brain.
