Chemistry Help! (Again)
Status
Not open for further replies.
T_Yamamoto
15,007
795
Here I go again,
Chem help please, thanks :)
-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-
Part 1
29) In his experiments Lavoisier showed that mass is not changed in chemical reactions. Which one of the following postulates of Dalton's Atomic Theory is supported by his discovery?
Options:
a)All atoms of the same element have the same mass.
b)Atoms combine in simple whole number ratios.
c)Atoms cannot be broken down into smaller particles.
d)Atoms are only rearranged in chemical reactions, not created or destroyed.
36) In his experiments Proust showed that the elements of a given substance are always found in the same proportion by mass. Which one of the following postulates of Dalton's Atomic Theory is supported by his discovery?
Options:
a)Atoms cannot be broken down into smaller particles.
b)Atoms are only rearranged in chemical reactions, not created or destroyed.
c)All atoms of the same element have the same mass
d)Atoms combine in simple whole number ratios.
37p1) DONE
37p2) DONE
49)Four different samples of substances made up of only Ni and Br were analysed to find the relative masses of each element. Which of following results indicates a different compound from the others?
Options:
a)20 g Br and 5.0 g Ni
b)16 g Br and 6.0 g Ni
c)12 g Br and 3.0 g Ni
d)28 g Br and 7.0 g Ni
Part 2
8) What is the specific heat of a substance if 16.0 kJ are required to raise the temperature of 405 g of the substance from 88.0°C to 173.0°C?
[Answer]J/g·°C
What is the heat required to vaporize 55.1 g of liquid ammonia, NH3, at its boiling point? The ΔH° of vaporization of ammonia is 23.4 kJ/mol. Use a molar mass with at least as many significant figures as the data given.
[Answer]kJ
13) Calculate the number of liters of 4.20 mol of hydrogen gas at STP.
[Answer]L
22p1) For the following combination of reactants, enter the formulae of the products in the space provided and give their states. Separate multiple products with a comma ",". (Type your answer using the format 2Na2SO4(aq) for 2 Na2SO4(aq). If there are no products, enter "none".)
BaO(s) + H2O(l)
[Answer]
22p2)What type of reaction is this?
Options:
a)Combustion
b)Decomposition
c)Single Replacement
d)Double Replacement
e)Synthesis
f)No Reaction
24) For the following combination of reactants, enter the formulae of the products in the space provided and give their states. (Separate multiple products with a comma ",". Type your answer using the format Na2SO4(aq) for Na2SO4(aq). Do not balance the equation. If there are no products, enter "none".)
Fe2(SO4)3(aq) + CaCl2(aq)
[Answer]
Options:
a)Combustion
b)Decomposition
e)Synthesis
f)No Reaction
25) For the following combination of reactants, enter the formulae of the products in the space provided and give their states. (Separate multiple products with a comma ",". Type your answer using the format Na2SO4(aq) for Na2SO4(aq). Do not balance the equation. If there are no products, enter "none".)
ZnCO3(s) + heat
[Answer]
Options:
a)Combustion
b)Decomposition
e)Synthesis
26) For the following combination of reactants, enter the formulae of the products in the space provided and give their states. (Separate multiple products with a comma ",". Type your answer using the format Na2SO4(aq) for Na2SO4(aq). If there are no products, enter "none".)
Cu(s) + Fe(NO3)3(aq)
[Answer]
Options:
a)Combustion
b)Decomposition
e)Synthesis
27) For the following combination of reactants, enter the formulae of the products in the space provided and give their states. (Separate multiple products with a comma ",". Type your answer using the format Na2SO4(aq) for Na2SO4(aq). Do not balance the equation. If there are no products, enter "none".)
NaI(aq) + Cl2(g)
[Answer]
Options:
a)Combustion
b)Decomposition
e)Synthesis
28) Fe2O3(s) + CO(g)
Fe(l) + CO2(g)
How many grams of Fe2O3(s) will be required to produce 5.80 moles of Fe(l)? Hint: Be sure to balance the equation first!
[Answer]g
29)2 NaClO3
2 NaCl + 3 O2
Determine the number of moles of O2 produced by the decomposition of 426 g of NaClO3.
[Answer]mol
30)CH4 + 2 O2
CO2 + 2 H2O
How many grams of CO2 are formed from the combustion of 2.50 moles of methane, CH4, in oxygen?
[Answer]g
31) What volume of oxygen, O2, would contain 9.00 moles of gas at STP?
[Answer]L
HamburgerBoy
27,111
318
37p1)Different isotopes of the same element have different numbers of what? (Select all that apply.)
Options:
a)Protons
b)Electrons
c)Neutrons
d)Alpha Particles
37p2)Different isotopes of the same element have the same number of what? (Select all that apply.)
Options:
a)Protons
b)Electrons
c)Neutrons
d)Alpha Particles
r u kidding
PhoKingGuy
4,685
I haven't done chemistry since my MCAT and this is all still easy for me. You fail at life, im not doing your homework for you.
Status
