- Jan 2, 2006
- 10,455
- 35
- 91
I don't really understand the chemistry involving corrosion of chips, contacts, etc when an electronic device that's turned on gets in contact with salt water.
The end result is a shorted out device, possible permanent damage, and lots of lots of corrosion, which I assume is either salt buildup from the salts initially dissolve in the water, or deterioration of the metal itself. I'm not sure which. Note that anything I say below can be wrong, so let me know how to correct it.
My current line of thought is that if your device falls in salt water, you should:
1. Immediately take out the battery. Don't press any buttons. Just take out the battery. Electric currents running throughout the device will hasten the corrosion and short circuit process. Short circuits can divert unregulated electricity to components not designed to handle the load, burning them out. The electrons in electricity combined with salt water serve to hasten the plating of conductive salts onto circuit boards and metal contacts.
Thus, you want to prevent the movement of electricity and the precipitation of salts out of solution that will coat your components and also corrode your metals. If a chip has already been overloaded, you're done for.
2. Taking the battery out solved the first problem. To solve the second problem you want to:
a. dissolve any corrosion or salt buildup already in the device (it's already there, guaranteed)
b. remove the buidups
c. dry the device
3. Ideally you want to flush the device with a liquid that will dissolve away corrosion, flush out the corrosion, and then evaporate cleanly, leaving your device nice and dry and clean.
4. If it got dunked in salt water, you want to decrease the concentration of salts that it's being exposed to. That means getting some distilled water or tap water in a pinch and submerging the device. Keep it wet. Keep the salts dissolved. Don't allow it to dry with salts left behind on the circuits. Pour out the old water that now contains some dissolved salts and soak it a second time in fresh water. Then dump and soak it again for a third time. Fresh water is generally not enough to remove hardened salt deposits and corrosion that have already formed.
5. Leave the phone in the fresh water and get yourself some denatured alcohol from a hardware store in the paint thinner section next to the acetone and turpentine. Alcohol will dissolve minerals and evaporate extremely quickly but it will not dissolve plastics or remove paint, unlike acetone. Denatured alcohol is used as a relatively long burning fuel and is very flammable. Use extreme care.
6. Pour the alcohol into a bowl and transfer the device into the alcohol and let soak. Agitate the entire thing to circulate alcohol around in the device. Mechanical agitations such as shaking or vibrating can help remove the deposits and dissolve them back into solution. If the circuit board is exposed you can use an electric supersonic toothbrush such as a Sonicare to brush off deposits. Pour out the alcohol, pour in fresh alcohol, and repeat the.
7. Take out the device and shake it of excess alcohol. Leave it in a dry place and the denatured alcohol will evaporate out on its own. Or leave the phone piled under a mound of rice to draw out any remaining moisture and liquid.
c. dry the device
