Checksum - help me understand it please
MichaelD
I know a checksum is there so you can ensure you got all the bits and bytes of the download. But how do I "use" it?
I'm downloading a Mandrake Linux Distro (won't be done for hours...it's 2GB+) and it has a checksum listed for it.
Once the DL is complete, what am I supposed to do w/the checksum? I know how to burn an .iso to a CD/DVD.
Here's what the checksums says:
5f09b941c03d0511862fcdf60f1526c4 Mandrakelinux-10.1-Official-Download-DVD.i586.iso
Well all a checksum is is the result of a mathmatical formula that uses the file as a number.
So basicly it takes the entire file, runs it thru the formula, and poops out a number at the end. They way the formula is suppose to work is that no 2 files will have the same checksum... even if only one bit was changed it would pop out a entirely different result.
There are 2 commonly used checksums... md5sum and sha1sum... I beleive. Md5sum is more common, but I think that somebody found a weakness in it that if you purposely modify a file in a very specific manner you may get it to pop out 2 of the same numbers. Not sure.
But it's probably md5sum. It'll say somewere in the file or in the file name. There is a command line program you can use for doing this. In Linux it's called md5sum and is usually aviable by default, but for windows you'd have to find and install a md5sum.exe program. Also there are a lot of other programs aviable that will also do it for you.
Thanks, Drag.
So, being that I'm DLing a Linux distro, there's a chance that once I un-rar the file, they'll be a checksum checker program called "md5sum" or similar in there somewhere?
Cool.
Thanks for your help. 🙂
Nope. I've never seen it bundled with something like that. It's standard for Linux people to have that by default, but a quick google will find it for you in Windows.
Generally for downloading big stuff I like using bittorrent better. With that it has it's own checksums that double check everything automaticly.. I beleive. You pretty much never have to worry about getting a corrupted download. (just as long as the original that started the torrent was fine). Plus it's faster.
Thank you, sybille.
After some figuring it out, I got the Windows version of md5summer to work.
I'm still a GUI guy...trying to learn Linux. 🙂
Thanks again.
