Checking battery charge using a multimeter?
The Sauce
4,741
34
My wife tends to leave batteries (among other things) lying all over the place - used, new...all mixed together. Can I use my multimeter to tell which batteries are good and, if so, can someone walk me through it?
shortylickens
80,287
17,080
Put one probe on one end of the battery, the other probe on the other end.
If its alkaline it should measure 1.5 volts (sometimes a little more). 1 volt or less and it probably wont run your gadgets.
yelo333
990
I'm no EE, but here is how I understand it: Some multimeters have a battery test function on them. It measures the voltage while applying a small load. Testing just open circuit voltage without applying a load can yield bad results.
The Sauce
4,741
34
Ah thanks. I should have actually looked at my multimeter first. Didn't realize that they came with battery testing functions. Mine has settings for AA, AAA (1.5V), and 9V. Awesome.
Eli
Super Moderator | Elite Member
8
That's handy.
Generally, you should test batteries with a small load.
JohnCU
Banned
Dec 9, 2000
16,528
4
how much of a load? you're already putting some load on it with the multimeter
FeuerFrei
9,144
929
Really. The multimeter should provide the load. <_<
Eli
8
lol
The typical load in the Voltage circuit of a multimeter is 10,000 Ohms.
frostedflakes
7,925
The ideal voltmeter has an infinite resistance. Obviously this isn't possible, but I think real ones do have pretty high resistances (on the order of megaohms). The idea is to put as little load on the device you're measuring as possible so that the reading you get is very close to the open circuit voltage.
herm0016
8,498
1,115
Originally posted by: frostedflakes
The ideal voltmeter has an infinite resistance. Obviously this isn't possible, but I think real ones do have pretty high resistances (on the order of megaohms). The idea is to put as little load on the device you're measuring so that the reading you get is very close to the open circuit voltage.
this.
i usually use 100 ohms or so (what ever is lying around near that value) to test batteries, a load on the battery means you are drawing some current from it. you check to see that the voltage drop with a current on it is not too much.
JohnCU
Banned
Dec 9, 2000
16,528
4
lol
so what do you suggest? i've never seen anyone measure a battery with resistor in the configuration.
Eli
8
lol
Well, it's not necessary. It will still give you an idea of State of Charge. But it's better to apply a load and watch the voltage.
A brand new AA battery should read around 1.55V.
A dead one will read around 0.9-1.1V.
futuristicmonkey
1,031
lol
For those dmm's which cost like $2.00, yes. Even the Canadian Tire Mastercraft dmm's have 1 megohm input impedance.
KK
15,903
4
If you need to place a load on a battery before reading the voltage, just get a piece of straight wire and connect each side to each end of the battery. Then you should be able to get an accurate reading.
herm0016
8,498
1,115
load=/= short circuit.
this is a good way to make a battery "pop" open, and to ruin it.
JohnCU
Banned
Dec 9, 2000
16,528
4
actually that is a hell of a load on the battery having to generate that much current. i think he was being sarcastic anyway.
frostedflakes
7,925
Yeah, that's not a good idea, heh. I doubt alkalines will explode or anything like when you short-circuit car batteries, but as herm mentioned it would probably damage the battery. The wire will also get very hot and could cause burns.
FeuerFrei
9,144
929
lol
And by 'load' I mean 'resistance.' erg
Adding resistor in series with the battery & voltmeter will just mess up the voltage reading. It'll read low.
JohnCU
Banned
Dec 9, 2000
16,528
4
lol
nah they mean put a resistor across the battery and then measure the battery as it is supplying power to the resistor.
DrPizza
Mar 5, 2001
49,601
167
111
www.slatebrookfarm.com
then wrap the wire around a nail a dozen times before connecting it to both ends of the battery. Your battery will be just fine for those 3 seconds it takes to measure the voltage.
But, it shouldn't be necessary for doing a quick check of which batteries are good and which are shot.
JohnCU
Banned
Dec 9, 2000
16,528
4
for my own fun i just measured a battery open circuit and short circuited (AAA)
open = 1.59V
shorted = 0.59V
herm0016
8,498
1,115
hmm.. an inductor. that would work fine as long as its quick.
Eli
8
lol
Ah, yeah. You're right.
