Svnla
Hi all,
Co worker has a 2001 Honda CRV with 120K miles and the yellow check engine light just on (solid yellow, not just blinking or on and off) this morning. The engine is still running fine, no rough running or sputtering or anything wrong. It never happend before.
I checked the gas cap to be sure it was tight, looked up on Google and not sure what to do next.
Any suggestions/advise? TIA.
Edit with update: We went to the local AutoZone and asked them to read it. The guy did it in a few minutes and he said it was P1456.
From the printout, it stated: emission control system, fuel system - probable causes - loose fuel cap, vapor canister saturated, fail vent, failed purge. I did look up on Google and so many suggestions, not sure which one is the right one for us.
Ok, shadetree mechanics, any suggestions or idea? We did tighten the gas cap very well again and just filled up the gas to 80%.
Update 2: Went to WalMart and got a Stant gas cap ($5 plus tax), replaced the old Honda gas cap with crack around the seal. The CEL was still on, went online and looked around. One of the poster from Honda Tech said let pull the fuse (back up radio) from the fusebox nears the battery for about 30 seconds. Did that, started the car, the CEL was gone. Happy. 😎
Thanks everyone.
Thanks everyone.
