- Nov 13, 2001
- 15,362
- 416
- 126
Code reader
Chiltons manual for every car in book or cd form
Detailed Description
OBD II Code Reader (1996 and newer)
Features:
This compact hand-held OBD2 tool offers light do-it-yourselfers and consumers a quick & easy way to find out why the "CHECK ENGINE" light illuminated on 1996 and newer cars, light trucks, mini-vans and SUVs - foreign and domestic. This little tool packs a big punch with its patented single-screen display and system status LEDs for a quick check.
Key Features and Functions:
Works on all 1996 & newer OBD2 Compliant Vehicles.
"Plug & Play" Interface. Connects to the vehicle and shows all necessary data in 15 seconds or less - no set up required.
Patented Single-Screen Display. Patented all-in-one display shows 19 vital pieces of information, including diagnostic trouble codes (DTCs), pending codes, emissions monitor status and more (U.S. Patent #6,687,584).
C.A.N. (Controller Area Network) Coverage. C.A.N. will be mandatory on all vehicles in 2008. It is the fastest way yet for OBD2 vehicles to speak with their computerized systems.
Erases Codes. Lets the user turn off the "Check Engine" light, clear codes and reset monitors.
Booklet and CD. Includes manual with DTC definitions in English, French & Spanish.
Support. Includes free Understanding OBD2 video and support by all ASE Certified Technicians via toll-free phone line or Internet.
System Status LEDs. Color-coded LEDs show quick emissions readiness status. This is great to use before getting an annual emissions "smog" check, buying a used car or taking a long road trip.
This is a super hot deal because this is the only one I could find that reads CAN codes under $150 and comes with a cd with all the code answers on it and is updateable.
It will pay for itself first time you use it to check what the reason for your check engine light is on. This and a Chiltons manual could save you thousands of dollars in labor costs. Hell make a few extra bucks on the side and diag co-workers cars as well. Most shops charge $50-$75 just to read the code the and extra ammout to shut the light off. Now you can do it yourself. Most emmision places will not check your car if the light is on. With this you can turn the light off and see if your car will still pass.
Very usefull tool for any car 96 or newer.
Features:
