Check engine light is coming on intermittently
oxygen sensor? ignitions? misfiring? ... hundreds of possibilities....
Give brand, model, year, trim, mileage, etc...
Could be anything.
You can either try and go to Autozone or similar when the light is on, or just wait until it's on solid and go have them pull the codes. That's really the only way you're going to figure it out.
It's a 1993 Ford Escort with a 5-speed manual transmission.
I did have the clutch replaced on Wednesday.
I checked the oil and it's a little low. Maybe I'll try throwing in some oil.
Otherwise it's driving fine
