Originally posted by: SuperTool
There is nothing wrong with the car. I've been driving with that check engine light for months now, and it performs as well, gets the same mileage, and has same tailpipe emissions. I can hold my hand to the tailpipe, and then lick it, and it's pure water on my hand.
Well that is certainly an interesting interpretation of an emissions inspection.
However, the whole point of the "EVAP" system is that it prevents gas fumes from entering the atmosphere. So it is reasonable that a failure in this system would fail your car.
It shouldn't be hard or expensive to diagnose/repair one of those codes, unless it is some completely off the wall problem.
But that valve is not there to prevent leaks. It's my understanding that it's there to seal the canister to test for its integrity. So as long as there is no problem with the canister, it's not a problem.
yes there is. you have an EVAP canister purge volume control valve that is broken.Originally posted by: SuperTool
Originally posted by: homestarmy
Just reset your ecu right before they inspect your car...
Maybe the law is different in CA.
