Unless you have a T3 running into your house, then you're wrong.Originally posted by: bigalt
why do you want to? the ping playing games will be worse, and any files you'd want to transfer back and forth will be WAY slower than a wired connection.
I'd say your better off routing your ethernet cables through your vents and under carpets and whatnot, but anyway, good luck!
Virtually any LAN > WAN.
The ping from the WiFi client to the access point is just a couple milliseconds.Originally posted by: bigalt
well i didn't look at them side by side, but i'm pretty sure that playing on xbconnect on my friend's wireless was choppier than playing on my wired across the hall. i suppose it could have been from different servers, but we figured it was because it took extra time for the router to get the info to the xbox and back.
Then you'd want to go Wired, not Wireless. Unless you get uber-highspeed stuff (e.g. 108g) your transfer rate is going to be pretty slow by comparison. Standard ethernet is the cheapest thing for the speed you'll get.Originally posted by: edro13
It would mainly be for FTPing large files to my XBOX from a PC on the same network.
